Afstellen achterderailleur
RaulAlonso
RaulAlonso 21 mei 2020 07:24
The Best Cordless Drills to Buy in This Year: Best Product Reviews
If you have a toolbox and regularly use it— either professionally in your day job or for DIY projects at home— you will surely know that a top rated cordless drill is an essential. Aside from being an incredibly versatile piece of equipment, a best cordless drill can make your job much easier. After all, there aren’t a lot of electric, engineering, or DIY projects that don't require you to have a drill at hand.
In this article, we have a few top cordless drills for you to consider.
➷➷➷ Further Reading: Afbeelding What is the best drill
Bosch PS32-02
The Bosch PS32-02 is armed with a brushless motor, which will give you more power than the common brushed motor in other power drills. The PS32-02’s advanced motor will also use the power from the Li-ion battery more efficiently, so your drill’s battery life will be better and it will also last longer to boot.
For a cordless drill that we fully considered to be “heavy-duty”, the PS32-02 is quite lightweight at just 2 pounds. The handle was obviously designed with comfortability and maneuverability in mind and we’re happy to report that it fulfilled its job perfectly. All of our testers and the majority of customers praised the great feel of this best rated drill in the hand.
The drill is also quite compact. It won’t bog you down when you need to work in cramped spaces and also has an LED flashlight to make it easier for you to work in the dark. A drill bit storage is integrated right into the drill for more convenience.
DeWalt DCD792D2
The DeWalt DCD792D2 is among the most technologically advanced cordless drills out there. Besides raw drilling performance and an ergonomic design, the DCD792D2 is Bluetooth-capable and can pair up with your smartphone via an app. This app can report information such as battery life, motor temperature, the amount of trigger pull, diagnostic information, and much more.
The DCD792D2 is a fairly well-balanced 20 volt drill. It offers enough power to handle most work (even heavy duty ones) but it is still gentle enough to be easy to handle.
Though this best portable drill may look bulky, at 3.4 pounds, it’s actually not bad. If you need to fix up a chandelier or attach lights to the ceiling, for example, your arm won’t tire easily.
✸✸✸ See It Here: Best cordless drill brands Afbeelding
Makita FD07R1
Just like the Bosch PS32-02, the FD07R1 is equipped with a brushless motor for better power efficiency and overall performance. And despite being a relatively lightweight and compact drill (weighing about 2 pounds,) the FD07R1 performs exceptionally well for its size. It has no trouble whatsoever punching through slabs of hardwood and similarly lightweight materials. However, be careful when you pitch it against concrete, this one isn’t made for heavy, industrial applications. Rather, the FD07R1 will fit right in the domestic scene as a home drill.
Kobalt KDD 1424A-03
Despite packing serious power, the 1424A-03 is the most affordable drill for the money on this list. It weighs a pretty hefty 4 pounds due to the upscaled motor, but in return, you get exceptional drilling speed. The 1424A-03 can rapidly punch multiple holes through hardwood and similar materials. This quirk makes it excellent for DIY-ers or homeowners needing an efficient, high speed power drill for works around the house.
Unlike other drills, which usually provide you with an extra battery, the 1424A-03 will only ship with one battery in the box. Don’t worry, though, this drill’s battery is a robust 24-volt cell and will give you ample battery life to finish whatever job you’re planning to do. This is also how Kobalt has managed to slash the 1424A-03 down so low.
Conclusion
So that’s our best cordless drill reviews Afbeelding! We hope you’ve found the drill of your dream in this article. Just in case you haven’t, though, just search through our site for more reviews just like this one. You will find a lovable drill in no time.
Until next time!
Laatst gewijzigd door RaulAlonso op 30 okt 2023 04:15, 9 keer totaal gewijzigd.
walter-
walter- 21 mei 2020 07:43
Neem je fiets mee naar de les :-).
Werkte het goed voor je er aan werkte?
Ik begrijp niet wat je bedoelt met schakelen tussen de tandwielen?
Kan je correct schakelen van het kleinste naar het 2de kleinste kransje -niet tandwiel? Dat moet eerst goed zijn.
Walter
Gebruikersavatar havana 21 mei 2020 07:45
Je vergeet een belangrijke stap, namelijk het pat richten.
bartaspin
bartaspin 21 mei 2020 12:41
Met die vijsjes, mooi woord trouwens, zet je de derialleurwieltjes recht onder je grootste en kleinste tandwiel. Als dat niet goed staat, lukt het afstellen ook niet.
walter-
walter- 21 mei 2020 12:57
RaulAlonso schreef: ↑21 mei 2020 07:24 ...
- Met de twee vijsjes zodanig afstellen dat de ketting niet van het grootste en kleinste tandwiel loopt
misschien aanvullen op deze stap;
- niet alleen zorgen dat de ketting er niet afloopt maar ook dat:
Op kleinste kransje: zonder derailleur aan te raken dat de derailleur net onder kleinste kransje staat en soepel loopt; dat is de start positie.
Dan kan je kabel aanbrengen.
lawnmower
lawnmower 22 mei 2020 01:17
Op je oude mtb?
Als je kabels niet goed lopen kun je blijven afstellen tot je een ons weegt....
Voordat je de kabel monteert, stelschroef helemaal indraaien en dan 1 hele slag uit, anders heb je geen ruimte meer voor kabelverlenging.
De vijsjes voor de afstelling van het bereik, doen niets met het schakelen midden in de cassette dus zelfs als die niet goed zouden staan kun je het schakelen door de cassette heen nog steeds goed afstellen.
bartaspin
bartaspin 22 mei 2020 08:28
lawnmower schreef: ↑22 mei 2020 01:17 Op je oude mtb?
🤔 Volgens mij zorg je er met de vijsjes juist voor dat je overal precies onder het tandwiel uitkomt met 1x schakelen. Door te beginnen met het vijsjes recht onder kleinste tandwiel te gaan staan.
Gebruikersavatar havana 22 mei 2020 08:36
Misschien handig om gewoon Nederlandse terminologie te gebruiken.
We hebben twee stelbouten (sommigen noemen het schroeven, feitelijk zijn het bouten). Deze regelen de maximale uitslag, dus hoe ver de derailleur naar links en naar rechts beweegt. Soms staat er L en H bij deze schroeven. L staat voor low limit, H voor high limit.
Ezelsbrug:
L = low speed = grote kansje
H = high speed = kleine kransje
Idealiter stel je de L en de H af zonder kabel gemonteerd. Zo weet je zeker dat limieten goed staan. Neem hier de tijd voor, gebruik behalve je ogen ook je gehoor. Aan het geluid van de ketting kun je goed horen of het kransje er recht boven staat. Voor de H-limiet moet je de derailleur zelf de juiste kant op duwen (want geen kabel gemonteerd). Dat vereist enige oefening, maar is prima te doen.
Dan hebben we een stelschroef die aan de kabel vastzit. Hiermee regel je de tussenstappen. Als de derailleur wat traag (of zelfs niet) schakelt als je lichter schakelt moet je 'm wat strakker afstellen als er niks gebeurt als zwaarder schakelt moet je 'm juist losser zetten.
Vervolgens hebben bepaalde derailleurs, o.a. bijna alle van Shimano, nog de zogenaamde B-schroef (er staat "3e" bij in het plaatje hieronder). Hiermee kantel je de derailleur als het ware wat. Als je hele grote kansjes gaat gebruiken zul je deze schroef vrij ver (of zelfs helemaal) moet indraaien om te voorkomen dat het bovenste derailleurwieltje tegen het kransje aanloopt.
Zoals @lawnmower terecht opmerkt is een correcte kabelloop een voorwaarde voor het überhaupt correct kunnen afstellen. Dat geldt ook voor een recht derailleurpat.
iroelho
iroelho 26 mei 2020 14:16
Dank je wel voor de heldere uitleg Havana!
walter-
walter- 26 mei 2020 14:27
En is het gelukt correct af te stellen?
marsman
marsman 26 mei 2020 14:35
Naar welke kant moet je de fijnstelschroef draaien om de kabel strakker dan wel losser te zetten op een Ultegra 8000 derrie? Ik heb het idee dat het vaak niets doet. Ik heb al heel wat keren staan draaien aan de fijnafstelling, maar het deed nooit wat??
walter-
walter- 26 mei 2020 15:08
Strakker is uitdraaien en dus tegen de wijzers in. Het maakt eigelijk de kabelloop langer.
Het is niet altijd even duidelijk als je op het einde van mogelijkheden tot uitdraaien komt. Dan is de schroef er helemaal uitgedraaid en kan niet verder. Maar soms pakt de schroef ook niet goed om terug in te kunnen draaien.
Dan maak je best even de kabel los en begin je opnieuw.
Walter
