Quarq DZero spider op Force 22 crank
evilhomer
evilhomer 23 jan 2017 16:36
Zoals de titel al zegt: ik wil graag een Quarq DZero spider op een Force 22 crank monteren. Echter, de Quarq-spider heeft een 8-bouten-bevestiging terwijl de originele Force-spider slechts met 3 bouten vastzit.
Simpelweg de Quarq-spider met 3 bouten bevestigen (en de andere 5 gaten leeg laten), lijkt niet te kunnen. Quarq noemt onder compatibele cranks/vermogensmeters alleen degene die met 8 bouten zijn bevestigd. Op BikeRumor geven ze volgende uitleg:
Why they couldn’t just make it fit the existing SRAM crank direct-mount standard. Because on the 3-bolt design, the spider or chainring actually rotates into place slightly, which could change the zero offset setting in the power meter. The eight bolt design locks it into place so it remains accurate once you actually start putting pedaling pressure on it.
Kortom, mag ik hieruit opmaken dat dit niet mogelijk is?
t.a.f.k.a.e.h.
Gebruikersavatar raven14 23 jan 2017 17:52
Vergeet het. Je hebt die Quarq Prime Power ready crankset (met 8 bouts interface) nodig (of een beperkt aantal vorige PMs met die 8-bouts interface. Dit was een antwoord van Quarq support op dezelfde vraag:
All Quarq and SRAM products go through heaps of testing. All cranksets must meet internationally recognized fatigue and ultimate strength standards, in addition to passing additional internal SRAM safety and performance standards. All SRAM cranksets including 3-bolt and 8-bolt designs from Quarq meet the same safety and performance standards.
As much as you and I both would like power meters to have uncomplicated cause and effects on all engineering aspects, it turns out that reality is messy (a shocker, I know). The big effects are easy to understand, but there are dozens of error sources that are 1% or less. Some are easy to measure and correct. Others are not. Our switch to 8-bolt addresses a number of these small error sources. Our internal testing and evaluation of the 8-bolt system yielded numerous advantages, enough that we decided to make the switch from the 3-bolt interface.
(moest het al passen, en ik vermoed van niet trouwens: niemand weerhoudt je dan van die setup toch eens te testen op accuratesse. Ik ben er zelf ook wel benieuwd naar)
Keezx
Keezx 23 jan 2017 21:46
Ik vroeg me dat ook af omdat ik ook zo'n SRAM crankset heb , maar:
De "splines" van de crank lijken iets anders gevormd, EN , het belangrijkste, de Quark spider heeft 8 "splines"en de gewone 10.....incompatible....
evilhomer
evilhomer 23 jan 2017 22:26
Dank! En helder. 8 om 10 splines, ik zie het nu pas...
Dan zit er niets anders op dan een Quarq inclusief cranks te bestellen. En bied ik binnenkort een splinternieuw Force crankstel te koop aan in het daarvoor bestemde subforum ;)
t.a.f.k.a.e.h.
