Twijfel Cube agree GTC pro vs Giant Defy Advanced 2 LTD
Hallo,
Cube Agree GTC pro 2015
http://www.cube.eu/nl/bikes/road-race/a ... nred-2015/
FRAME GTC Monocoque Twin Mold Technology
COLOR white´n´black´n´red
SIZE 50, 53, 56, 58, 60, 62, 64 cm semisloping
FORK CUBE CSL Race Carbon, Tapered
HEADSET CUBE I-t integrated, top 1 1/8", bottom 1 1/2"
STEM CUBE Performance, 31.8mm
HANDLEBAR CUBE Wing Race Bar, Compact
HANDLEBAR TAPE CUBE Grip Control
REAR DERAILLEUR Shimano 105 RD-5800GSL, 11-Speed
FRONT DERAILLEUR Shimano 105 FD-5800BLL, 34.9mm
SHIFT-BRAKE-LEVERS Shimano 105 ST-5800, 2x11-Speed
BRAKE SYSTEM Shimano 105 BR-5800
CRANKSET Shimano 105 FC-5800-L, 50x34T, Hollowtech II, 170mm (50/53cm), 172,5mm (56/58/60cm), 175mm (62/64cm)
CASSETTE Shimano 105 CS-5800, 11-32
CHAIN Shimano CN-HG600-11
WHEELSET Fulcrum Racing 77
TIRES Conti Grand Sport Race SL, 25-622
SADDLE CUBE RP 1.0
SEAT POST CUBE Performance Post, 27.2mm
SEATCLAMP RFR Close 31.8mm
PRICE 1299 EUR
WEIGHT 8,55 kg
ART. NO 675200
SADDLE CUBE RP 1.0
PRICE 1299 EUR
WEIGHT 8,55 kg
ART. NO 675200
Giant 2015
http://www.giant-bicycles.com/nl-nl/bik ... 503/75921/
FRAME
Maten S, M, M/L, L, XL
Kleuren Comp / White
Frame Advanced Grade Composite,
Voorvork Advanced-Grade Composite, Alloy OverDrive Steerer
Demper N/A
ONDERDELEN
Stuur Giant Contact
Stuurpen Giant Contact
Zadelpen Carbon D-Fuse
Zadel Giant Race
AFMONTAGE
Shifters Shimano 105
Voorderailleur Shimano 105
Achterderailleur Shimano 105
Remmen TRP SPYRE Alloy arm
Remhendels Shimano 105
Cassette Shimano 105 11-28, 11-Speed
Ketting KMC X11L
Crankset Shimano 105 34/50
Bottom Bracket Shimano, Press Fit
WIELSET
Velgen Giant P-R2 Disc
Naven Giant Performance Tracker Road, Sealed Bearing
Spaken Sapim Race
Banden Giant P-R3, Flat Guard, Front and Rear Specific, 700x25
OVERIGE
Gewicht 8,90 kg
FRAME
Demper N/A
ONDERDELEN
Stuur Giant Contact
Zadel Giant Race
AFMONTAGE
Ketting KMC X11L
WIELSET
Spaken Sapim Race
OVERIGE
Gewicht 8,90 kg
Kijk naar de maten (geometrie) van je huidige fiets en kijk hoe dat uitkomt bij de frames die je op het oog hebt.
Vooral kijken naar virtuele lengte bovenbuis en hoogte balhoofd. Kijk hoe je uitkomt met spacers bijv.
als je naar je huidige fiets kijkt zou je dan daar veranderingen bij willen kwa maatvoering/geometrie/handling van de fiets/etc? Dan kan je dat als uitgangspunt nemen om je perfecte fiets te vinden.
Mijn oog is nu ook gevallen op een 2014 Sensa Giulia Custom. Deze is in de aanbieding en volledig ultegra afgemonteerd.
Ook hier graag wat meningen over of dit wat is.
De keuze zou dan voor de dubbel of de trippel van 1559 gaan.
2014
Sensa Giulia Custom
Frame: Monocoque Generation5 - Zero Void Curing - UD Carbon Fiber
Front Fork: Supra Full Carbon Monocoque Gen5 1.5
Group: See above
Seatpost: Deda RS01
Handlebar: Deda RHM01
Stem: Deda Zero1
Wheels: Supra RA Pro
Tires: Schwalbe Lugano
Saddle: San Marco Era
Sizes: 50 - 53 - 55 - 58 - 61 cm (sloping)
Color: Shiny Carbon Clear UD + White + Red
Weight: * 7.0 KG
Price:
Full Ultegra DI2 2 X 11 (53/39 or 52/36 or 50/34) Euro 2999,- Nu 2199,-
Full Ultegra 2 X 11 (53/39 or 52/36 or 50/34) Euro 2299,- Nu 1761-
Mix* Ultegra 2 X 11 compact (50/34) Euro 2125,- Nu 1559-
Mix** Ultegra 3 X 10 Euro 2125,-
Nu 1559-
Mix* = Ultegra 6800 + Br561 + FcRS500 + Cs&Cn 105
Mix** = Ultegra 6700 + Br561 + FcR563 + Cs&Cn 105
2014
Sensa Giulia Custom
Group: See above
Seatpost: Deda RS01
Stem: Deda Zero1
Weight: * 7.0 KG
Price:
Nu 1559-
Je wilt een goed onderbouwd advies, wel dan zul je zelf moeten investeren.prokiter schreef:Bedankt voor de reactie.
Zover heb ik er geen verstand van helaas.
Je hebt al een fiets dus uitstekend vergelijkingsmateriaal.
1] Zit je perfect op je fiets of zou je aanpassingen willen?
-welke maat heb je nu? Wat is je lengte en de binnenbeenlengte?
- hoeveel mm spacers zitten er onder het stuur
- etc
2] Zoek de geometrietabel van de Cube Attempt 2009. Zodat je bepaalde maten zoals virtuele bovenbuis en balhoofdlengte kunt vergelijken met andere fietsen. Bij elke fiets worden de geometrietabellen geplaatst.
3] Ga voor jezelf na of je een dubbel of een tripel wilt.
4] Schijfremmen ja of nee
5] etc
Breng in kaart/definieer hoe je perfecte fiets eruit ziet. Dan heb je tenminste aanknopingspunten naar waar te kijken als je verder zoekt.
De geometrie van de 2009 Attempt en de huidige Agree GTC is ongeveer gelijk. De Defy heeft over het algemeen een 2cm hogere balhoofdbuis. Alleen als je nu 3cm spacers of meer onder je stuurpen hebt hebt zou ik voor de Defy kiezen.
