Eindelijk is het zo ver. Heb speling in mn Achterwiel Easton Vista. t enige lullige is dat dit binnen 5000 km gebeurt.
Waar ik niet zo blij mee ben zonet nog even langs lokale wielerzaak gereden en konen er niks tegen doen. Idustrie lagers. Kan je dit euver zelf verhelpen bij easton wielen of kan ik fijn weer eens richting mn goedkoop fietsenzaak en daar maar weer eens der voor gaan zorgend dat dit verholpen wordt?
Speling in een Easton wiel
moriquendi
Hoi,
Easton wheels schrijft het volgende over speling op de lagers, ik hoop dat je wat engels kan lezen;
Q. How do I adjust the bearings on my Easton wheels? A. Simple…you don't.The bearings on Easton wheels do not need adjustments. n all models except for Circuit Comp, the hub has an internal spring that makes the bearing self-adjusting. While the Circuit Comp does not share this feature, we devised a clever way to pre-determine the bearing preload during factory assembly, so, again, there is no adjustment necessary. If you are experiencing some lateral play, there is no need for alarm; it's your assurance that the bearing is running as efficiently as possible.In our design, there will be more inherent play, and here's why. All bearings have some play in them. If there were zero play, then the bearing would seize. Cartridge bearings are intended to take radial (vertical) loads, and are not particularly good at resisting lateral loads. Fortunately, lateral loads are not a large component in typical bicycle wheel conditions. When you ride, even when leaned over in a turn, the loads remain perpendicular to the axle.Removing the play from bearings is typically done by threaded adjustment. We chose to forgo having such and adjustment because most people, bike mechanics included, tend to over tighten the bearing, their goal being to remove any side play. In so doing, they constrict the function of the bearing. Then, when the quick release is tightened, it further binds the bearing by compressing the axle. This causes significant increases in friction and decreases the life of the bearing.Our design incorporates a slip fit bearing on one side of the hub shell. A small spring is located inboard of the slip fit bearing. This serves to regulate the preload on the bearing so that it runs free. A small amount of play indicated at the rim is your assurance that the bearing runs free.How much play is too much is a very nebulous and difficult thing to ascertain. If there is a large "dead spot" when you pull the rim back and forth laterally (with QR tightened in the frame), then maybe the wheel is outside of the normal tolerance. There are many reasons that this can happen, and it includes a bad bearing, an undersize axle, oversized end cap, or an oversize slip fit bore. All of these things are very easy to correct. In fact, if your hub had such an issue we could have diagnosed and repaired it quicker than the time it took to write this explanation. If you are handy with tools, you can undertake the procedures yourself, (illustrated instructions online) but more likely there isn't a problem per se, just a re-orientation to the function of our hubs. That said, if you suspect that there's too much play, you can always contact our tech support staff for further advice and / or service.
Heb je er wat aan ?
Ciao.
Heb je er wat aan ?
Ciao.
ik had bij mijn circuit wielen speling in het achterwiel, na 3 maanden kreeg ik een nieuw wiel gelukkig had ik op mijn verjaardag een paar Zonda's gekregen 3 maanden op een wiel valt ook niet mee
Veltec is traag met afwikkelen van garanties, carbon frame met scheurtje duurde ook vele weken
Funny the way it is
Ik had ook wat speling op mijn (Circuit) achterwiel. Met Veltec contact opgenomen en via mijn dealer teruggestuurd. In een week was het wiel klaar en netjes voorzien van nieuwe lagers.
Even contact opnemen met mikevelter@veltec.com
Valt gewoon binnen garantie.
moriquendi
Naja t ziet er naar uit dat ik dit zelf maar niet ga oplossen dus dadelijk maar naar stadler en kijken hoesnel ze daarmee zijn daar loopt t niet over veltec maar Grofa is hier in Duitsland de inporteur van Easton
