Vraag hier naar het door jou gezochte onderdeel of fiets
de zwarten
de zwarten
23 okt 2007 12:59
VBC=variable bolt circle.
Álle info welkom (alleen al de vraag of ze te koop zijn en waar), compabiliteit kettingbladen, ervaringen, of ze überhaupt de versie met zilveren kettingbladen ergens liggen hebben (alleen met zwarte gevonden op speedgoatcycles),
een mail naar White Industries is onderweg...
thx...
de zwarten
de zwarten
24 okt 2007 17:26
Dit was de reactie die ik zeer snel via mail ontving, service @ WI!
Q&A:
1. It's a pity the beautifull silver polished designed outer chainring is not available, since it is for the ENO. Will it ever come out in the near future?
The rings will remain black since it is a hard anodized coat. We can not retain the polished silver look with a hard anodized coat as the metal turns to a flat grey color.
2. Can the outer WI-chainring be combined with whatever brand inner chainring? Can a ENO ring be put on this VBC alone (single speed crank style)?
You can combine the outer ring with another manufactures five bolt inner ring, however, shifting is best when you use the two rings in tandem. The spline on the VBC crank is the same as the ENO crank spline so a single ENO ring can be run on the VBC arm. The VBC is designed for road bikes and not for mountain bikes. The Q factor is extremely low and the crank would interfere with the chainstay if you tried to use it on a mountain bike. Conversely, if you had the ENO crank you could use the VBC rings to create a double off road gearing combination.
3. What sizess of chainrings can I actually choose from? I would like 52-42 be available.
Inner ring 24-38 in two tooth increments. Outer ring 38-54 in two tooth increments.
4. Can I order from you guys directly, I mean, are you also selling retail yourselves? And what is your shipping policy (overseas?).
In the Netherlands, you can purchase our products through Singlespeed Central: JJ@singlespeed.nl
5. Why can't I highlight the crank specs from the vbc on your website?
I'll try and get the link corrected. Here is an earlier version, but not complete in ring sizes we offer
http://www.whiteind.com/VBC-specs.html[/i]
kronik
kronik
24 okt 2007 19:03
is dit voor je nieuwe speeltje lieven?
Koga miyata Gentslux
Willier Cento1
de zwarten
de zwarten
24 okt 2007 19:09
het is een optie, maar de andere optie is een zilveren record... en die heb ik al
Deze optie is echter echt niet verkrijgbaar met zilveren bladen (silver is the new black), wegens de incompabiliteit van andere buitenbladen met de WI crank (maakt gebruik van een soort spline bevestiging, Boone titanium maakt er ook zo, maar dan kan je geen binnenblad meer monteren...
Tot zover de info, de rest komt als alles binnen is (en de winter is nog lang en ik heb geduld!
