cannondale supersix dura ace di2
HI, I am new to the site (and new to The Netherlands). I recently tested for about 2 hours the cannondale supersix hi-mod di2 and fell in love with it. The specs are attached and given the total price I would appreciate some vews from more expert riders, in particular on the reliability of Di2
many thanks,
Marco
FRAMESuperSix Hi-MOD, BB30, internal DI2 routing
FORKSuperSix, Hi-MOD full carbon, 1-1/8" - 1.5" steerer
CHAINShimano Dura-Ace 7900 Shimano Dura-Ace 7900
RIMSMavic Kyrium SL Black
SPOKESMavic Kyrium SL Black
TIRESSchwalbe Ultremo ZX, 700x23c
PEDALSdura ace SPD-SL
BOTTOM BRACKETCannondale Hollowgram SL, ceramic bearings
FRONT DERAILLEURShimano Di2, 34.9mm clamp
REAR DERAILLEURShimano Di2
SHIFTERSShimano Di2
HANDLEBARSFSA K-Force Carbon Compact
STEMFSA OS-99 CSI, 31.8
HEADSETSuperSix, 1.5 lower bearing, 30mm carbon, w/5mm hidden alloy top cover
BRAKESShimano Dura-Ace 7900
BRAKELEVERSShimano Dura-Ace 7900
SEAT POSTFSA K-Force Carbon SP-RK-160, 31.6mm, 350mm
WHEEL SIZE700c
WHEEL RIMSMavic Kyrium SL Black
SADDLEFi'zi:k Antares, Kium railes
many thanks,
Marco
SHIFTERSShimano Di2
WHEEL SIZE700c
Reliability of Di2 turns out to be very good. It's been on the market now for quite some time and there weren't many complaints. Even long-distance triathletes and CX guys are very positive.
That Cannondale is great frame (from what I've heard). However, I don't understand why C'dale mounts those cheep and crappy Mavic wheels...
Sensa schreef:Cannondale problem on more bikes.
Great frame but wheels, saddle and other stuff is cheap and pulls de bike down.
WHEEL RIMSMavic Kyrium SL Black. Cheap and pulls the bike down???
Wie de raceschoen past... trekt hem aan.
sharkman113
Well ....in this case the price/value balance went completely the wrong way. Problem is Cannondale choose stuff that is cheap to buy oem but that isn't the best in business or matches best with the bike.
The supersix frameses is one of the best around and works fine in a custom build setup (but is no more than a compromise in the way they come as a complete bike.
Downfall is that cannondale doesn't produce a "real" di2 frameset but takes a standard hi mod frameset and drills a few holes afterwards (cable stoppers are still on which is a nono for a real di2 frameset).
So unless you can get a di2 at a bargain/discount which leaves room for customizing I would leave this package alone and look somewhere else (but this goes even more so for the Super record team bike.....
(best for the supersix line are the 105 of the Red package).
fietsvriend
I tested DI2 last year for six weeks. And it was great. If I had the money to buy it, I would. Immediately. No doubt about it. The shifters work fantastic, the sound when you change gear is superb and the system never failed in those six weeks I rode with it. I cannot offerd it, but when you can, there's only one advice: buy it!!!
Michiel
Flores schreef:Sensa schreef:Cannondale problem on more bikes.
On more bikes.. so in general frame is better then the parts the build the bike with.
And i had them, but give some good easton.
They give me a more truted feeling.
Guys some of your comments put under discussion the combination between the frame and di2 (objectively good) with wheels and other elements. I have realized that I am sharing messaged qith a quite professional and experienced group (while I am a bit of an italian middle aged novice).
Considering that the offer I have for the above package is certainly not a bargain at 6250 eur, do you have other suggestions / combinations for the price ?
I wanted to try the pinarello dogma 60.1 but cannot find a shop that would allow a test.
sharkman113
Think about this. A connondale a great value for money and the supersix frameset is at least as good as the dogma (probably better, but dogma could win on looks for some people) at approx. half the price.
Dogma is a nice ride but way overpriced and a bit too heavy.
Di2 is nice (but only has an advantage in bad weather/rainey rides) but if you're not stuck I would go for the Cannondale with the Sramm red gruppo which rides just as nice as the DI2 at allmost half the price....
