ArVee
Gebruikersavatar ArVee 24 okt 2026 21:33
Alle twee goede tips, dank U.
Bikers are not alone
DDX 20 nov 2026 20:28
Al paar keer eerder gehad dat strava opeens een rechte lijn trekt.
Dacht laat ik claude eens die fit file laten bekijken :
The FIT file itself is fine. The GPS track is complete and continuous, but one timer “start” event is missing, and Strava and Komoot handle that differently.
What happened
Your Garmin auto-paused at 16:23:29, about 2.9 km in, near the start by the Amstel. When you rode on at 16:26:27, the device kept recording, but it never wrote the matching auto-resume event. The event log looks like this:
16:16:18 start manual
16:23:29 stop_all auto
← missing "start" at 16:26:27
16:35:10 stop_all auto ← second stop in a row
16:35:20 start auto
That leaves 524 valid GPS records (16:26:27 to 16:35:10, about 4 km) in a stretch the event log says is “paused.” This is the ride along the Amstel down to Ouderkerk and the first part west toward Amstelveen.
Why the two apps differ
Strava follows the timer events, so it treats that whole stretch as paused, drops it, and connects the dots with a straight line. That’s the diagonal across the Middelpolder in your screenshot. Komoot ignores the events and plots every GPS record, so it shows the real route. The device’s own totals agree with Komoot: the session’s timer time (8,320 s) is exactly 523 s more than what the events add up to, which is that missing segment.
Because of this, Strava is probably also showing a slightly lower distance and moving time for this ride.
En direct een nieuwe fit file die gefixt was.
Even doorgevraagd en meteen een pagine die ik kan hergebruiken voor een volgende keer.
En mocht je er zelf last van hebben :
https://dl.a2000.nu/fit-autopause-fixer.html
