Bianchi 1885 de opbouw.
meendering
meendering 11 jan 2006 00:27
Heb 5 dagen terug een mail gestuurd. Valt me wel een beetje tegen, of zal die niet aangekomen zijn.
Als ik iets hoor dan post ik het hier wel ff..
bike_add1ct
bike_add1ct 11 jan 2006 01:55
Het blijven Italianen hè, niet teveel van verwachten dus...
meendering
meendering 11 jan 2006 17:27
Zo vandaag een mail terug gehad.
[uit de mail gehaald:]
SPECS:
- Hydroformed down tube and top tube
- Exclusive Reparto Corse tubing design
- Combination of 2 tubesTriple and 1 tube Double-butted    aluminium.
- Carbon seat stay
- New Hydroformed tubes which increase the stiffness
- Thanks to the rigidity the frame respons quickly on all “moves”
- Comfortable thanks to the carbon seat stay
MATERIAL:
- Aluminium frame, 7000 series, R&D Bianchi custom design, combination of triple butted and
double butted tubes on main triangle and carbon rear seat stays.
- Down Tube & Top Tube made by Hydroforming technology (HF).
- The Hydroforming process to produce tubes is called THF and consist using hi water pressure
into special moulds which permit having complex shapes in one piece. The hi-water pressure,
combined with external loads, allow the tube to be copied to the shape of the mould.
- This technology is becoming very frequent in the car and aeronautic industry.
- The main characteristics are:
1.precision of +-0,05mm, comparable to what achieved by machining;
2.consistent thickness of the formed components;
3.flexibility in shape design and excellent repeatability.
- Exclusive R&D Bianchi forged rear drops out and head tube, Compact Steering System 1“1/8
semi-integrated type.
-This frame is TIG welded, “flat bead” technique, the heat-treatment is made following
Bianchi specification and, before the painting, it undergo an anti-corrosion superficial
protection treatment.
SIZES
- 49>63 x 2cm
WEIGHT
- Kg.1,580
GEOMETRY
Iemand verstand van de geometrie?
.marcel.
.marcel. 11 jan 2006 18:19
Quoten: Origineel geplaatst door meendering op 03 Januari 2006
Dankje! Heb thuis een setje zwarte Easton stuurlint liggen. Met mooie Easton end-caps.
Bianchi stuurlintjes zullen er ook super bijstaan.
hit the road jack
delsol
delsol 11 jan 2006 21:30
je moet vanuit gaan dat 1.5 kg het kleinste maat frame is.
mooie fiets
meendering
meendering 11 jan 2006 23:11
Ik heb hem destijds met vork gewogen. (was niet helemaal goed gemeten).
Kwam uit zo rond de 2KG
Prima gewicht lijkt me.
Kan iemand iets vertellen over de geometrie van mn frame?
bike_add1ct
bike_add1ct 12 jan 2006 03:51
Wat wil je erover horen??? Alle gegevens staan in dat tabelletje...
meendering
meendering 12 jan 2006 20:27
Ik zal eens in de fiets kijken, daar staan bij elke fietsen bepaalde waardes. Dacht dat deze aangeven hoe sportief de fiets is. (hoeken)
meendering
meendering 18 jan 2006 00:11
Fiets is inmiddels af. (moet nog frameprotectors plakken en dan is ie helemaal af)
Heb afgelopen zondag een klein stukje gefietst om even te checken of alles het naar behoren deed. Voelde erg strak aan moet ik zeggen!
Hoop binnnen nu en een paar week de eerste tocht te kunnen maken op mn nieuwe aanwinst.
daveke
daveke 20 jan 2006 14:46
Aparte fiets! Dat celeste blijft gewoon mooi..
Science of Performance!
fietslicht
fietslicht 20 jan 2006 21:12
Heb voor mijn vriendin net een Bianchi 1885 frame gekocht, laten we afmonteren met Campa centaur en een Miche compact krank en campa proton wielen.
Waar het ff om gaat is het volgende: De fiets die jij hebt heeft een net wat andere kleurstelling dan de die van mijn vriendin. De grijze delen zijn wit en de witten delen zijn grijs. Ziet er in een keer anders uit dan.
Is het model dat jij hebt gekocht echt het 2005 model en die van mijn vriendin het 2006 model is het 2005 model daardoor niet meer verkrijgbaar?
Vind het bianchi die jij laat zien op de foto wel net wat mooier namelijk!
Weet iemand dit?
Etymologisch is het woord fiets niet te verklaren.
