Cancellara gaat voor uurrecord
simen
simen 27 dec 2013 10:48
Als erkent tijdrijder moet je zoiets als het uurrecord altijd eens een keer publiek overwegen.
Liefst in het putje van de winter.
Staan je sponsoren weer even in het volle licht.
Zij is ook tegen
klimmer
Gebruikersavatar klimmer 17 mei 2014 19:57
klimmer schreef:De regels zijn zeer strict: inderdaad creativiteit gevraagd. Ook de (zittende) houding is vastgelegd: de handen houden het kromme stuur vast.
Hour Record
3.5.026 The Hour Record is the greatest distance achieved in one hour on a traditional bicycle, as defined in
articles 1.3.006 to 1.3.010 and 1.3.019 of the rules, and as further defined in the following specifications:
• Triangular frame composed of straight, circular section tubes with a minimum diameter of 2.5 cm.
• Traditional style handlebars with an overall width of 50 cm maximum and 34 cm minimum.
• Two wheels of equal diameter, measuring 65 to 70 cm, including tyres.
• Tyre section of a minimum of 16 mm and a maximum of 25 mm.
• Spoked wheels with a minimum of 16 and a maximum of 32 spokes; the spokes may be round,
flat or oval provided that none of their cross-sections exceeds 2 mm. (See diagram 1 below).
• Shallow, unelongated, non-profiled rims; shallow rims are understood to be rims whose crosssection
fits inside a 2.2 cm square. (See diagram 2 below).
• Other measurements in accordance with those defined in articles 1.3.012 to 1.3.017 (see figure
“Measurements”) and 1.3.022, 1.3.024 and 1.3.025.
(1) The spokes may be round, flat or oval as long as the width of a cross-section at any point is no
broader than 2 mm in any direction.
2 mm
(2) Shallow rims are understood to be rims whose cross-section fits inside a 2.2 cm square.
2.2 cm
2.2 cm
Riders must wear a helmet certified according to international safety standards, intended solely for
the purposes of protecting the head, without a visor, and without any devices or shapes added to or
moulded into the helmet with the intention of or having the effect of reducing air resistance.
Met de recente reglementswijziging dat uurrecordfietsen aan dezelfde eisen voldoen moeten als endurance baanfietsen (achtervolging of puntenrace?) ontstaat een heel ander technologisch vertrekpunt. Het is wachten op meerdere kandidaten aanvallers voor het werelduurrecord! Niemand wil de eerste zijn. De laatste maakt de meeste kans een aantal jaren houder te blijven.
mrcoffee
Gebruikersavatar mrcoffee 20 mei 2014 09:44
Livio Livius schreef:Voor mij niet, alleen een groot kampioen mag voor mij houder zijn van het werelduurrecord. Heeft voor mij te maken met de romantiek van de sport.
Wat een gezwets!
Als iemand een uur lang zich verrot kan rijden en meer afstand aflegt dan iedereenm voor hem heeft gedaan ben je gewoon kampioen. Wat dat betreft is tijdrijden, en het uurrecord in het bijzonder, een kwestie van veel vermogen over lange tijd. Heeft niks met romantiek of koersinzicht te maken. Gewoon koele cijfertjes.
Ik kan mij voorstellen als je veel vermogen hebt, talent, heel veel tijd op de baan doorbrengt en je niet af hoeft te laten leiden door koersjes en volledig gefocust voor dat uurrecord kan gaan dat er inderdaad wel eens een onbekend konijn uit de hoge hoed kan komen.
NicoNB
Gebruikersavatar NicoNB 20 mei 2014 10:08
mrcoffee schreef:Ik kan mij voorstellen als je veel vermogen hebt, talent, heel veel tijd op de baan doorbrengt en je niet af hoeft te laten leiden door koersjes en volledig gefocust voor dat uurrecord kan gaan dat er inderdaad wel eens een onbekend konijn uit de hoge hoed kan komen.
Een voorbeeld van een onbekend konijn :)
MarkVeenstra
Gebruikersavatar MarkVeenstra 26 mei 2014 14:52
We moeten dus bij elk sportevenement naast de uitslag ook een idols verkiezing onder het publiek houden om te bepalen of iemand wel "mag" winnen eigenlijk....
Of nog beter.., bij elk sportevenement moeten we Livio even bellen om te vragen welke van de deelnemers die aan de start staan een groot kampioen is.
Wel lastig, want dan mogen alleen grote kampioenen winnen. ergo, er komen geen "nieuwe" kampioenen meer. Dus uiteindelijk houden we geen enkele winnaar meer over. :lol:
Livio Livius
Livio Livius 26 mei 2014 15:31
MarkVeenstra schreef:We moeten dus ..... geen enkele winnaar meer over. :lol:
Inderdaad :mrgreen: .
Zorro
Gebruikersavatar Zorro 26 mei 2014 18:12
Ik las toch vorige week of de week daarvoor zelfs dat Cancellara voorlopig even afziet van een poging gezien de nieuwe UCI regels: http://www.nieuwsblad.be/sportwereld/cn ... 7_01109586
U2-11 O'Clock Tick Tock
