Specialized S-Works E5 alu frame
patmaessen
Hoor het wel, hou me in ieder geval aanbevolen. Abel, heb je ook een pm gestuurd.
fiets van Avel is net iets te groot het is een 62
Zie ook:
Size
50 cm
52 cm
54 cm
56 cm
58 cm
62 cm
Stand Over Height
721mm
744mm
765mm
787mm
809mm
843mm
Seat Tube Length
430mm
480mm
500mm
520mm
540mm
580mm
Top Tube Length
525mm
537mm
548mm
565mm
582mm
605mm
Head Tube Length
110mm
120mm
140mm
160mm
190mm
220mm
Head Angle
72.5°
72.5°
73°
73.5°
73.5°
74.0°
Seat Angle
75.0°
74.0°
73.5°
73.3°
73.0°
72.5°
Wheel Base
971mm
975mm
978mm
986mm
1003mm
1018mm
Chain Stay Length
405mm
405mm
405mm
405mm
407mm
410mm
Front Center
577mm
580mm
583mm
591mm
605mm
617mm
Fork Offset
45mm
45mm
45mm
43mm
43mm
43mm
Stem Length
90mm
100mm
110mm
120mm
120mm
130mm
H/B Width
40 C-C
42 C-C
42 C-C
42 C-C
44 C-C
44 C-C
Crank Length
170mm
170mm
172.5mm
172.5mm
175mm
175mm
Seat Post Length
300mm
350mm
350mm
350mm
350mm
350mm
* TT is measured horizontally from center of HT to center of ST
Zie ook:
Size
50 cm
52 cm
54 cm
56 cm
58 cm
62 cm
Stand Over Height
721mm
744mm
765mm
787mm
809mm
843mm
Seat Tube Length
430mm
480mm
500mm
520mm
540mm
580mm
Top Tube Length
525mm
537mm
548mm
565mm
582mm
605mm
Head Tube Length
110mm
120mm
140mm
160mm
190mm
220mm
Head Angle
72.5°
72.5°
73°
73.5°
73.5°
74.0°
Seat Angle
75.0°
74.0°
73.5°
73.3°
73.0°
72.5°
Wheel Base
971mm
975mm
978mm
986mm
1003mm
1018mm
Chain Stay Length
405mm
405mm
405mm
405mm
407mm
410mm
Front Center
577mm
580mm
583mm
591mm
605mm
617mm
Fork Offset
45mm
45mm
45mm
43mm
43mm
43mm
Stem Length
90mm
100mm
110mm
120mm
120mm
130mm
H/B Width
40 C-C
42 C-C
42 C-C
42 C-C
44 C-C
44 C-C
Crank Length
170mm
170mm
172.5mm
172.5mm
175mm
175mm
Seat Post Length
300mm
350mm
350mm
350mm
350mm
350mm
patmaessen
Quoten: Origineel geplaatst door Sharkman op 11 Mei 2007
Zie ook:
Size
50 cm
52 cm
54 cm
56 cm
58 cm
62 cm
Stand Over Height
721mm
744mm
765mm
787mm
809mm
843mm
Seat Tube Length
430mm
480mm
500mm
520mm
540mm
580mm
Top Tube Length
525mm
537mm
548mm
565mm
582mm
605mm
Head Tube Length
110mm
120mm
140mm
160mm
190mm
220mm
Head Angle
72.5°
72.5°
73°
73.5°
73.5°
74.0°
Seat Angle
75.0°
74.0°
73.5°
73.3°
73.0°
72.5°
Wheel Base
971mm
975mm
978mm
986mm
1003mm
1018mm
Chain Stay Length
405mm
405mm
405mm
405mm
407mm
410mm
Front Center
577mm
580mm
583mm
591mm
605mm
617mm
Fork Offset
45mm
45mm
45mm
43mm
43mm
43mm
Stem Length
90mm
100mm
110mm
120mm
120mm
130mm
H/B Width
40 C-C
42 C-C
42 C-C
42 C-C
44 C-C
44 C-C
Crank Length
170mm
170mm
172.5mm
172.5mm
175mm
175mm
Seat Post Length
300mm
350mm
350mm
350mm
350mm
350mm
Zag op de foto al dat het een behoorlijk groot frame is. Jammer, blijf gewoon zoeken.
Zie ook:
Size
50 cm
52 cm
54 cm
56 cm
58 cm
62 cm
Stand Over Height
721mm
744mm
765mm
787mm
809mm
843mm
Seat Tube Length
430mm
480mm
500mm
520mm
540mm
580mm
Top Tube Length
525mm
537mm
548mm
565mm
582mm
605mm
Head Tube Length
110mm
120mm
140mm
160mm
190mm
220mm
Head Angle
72.5°
72.5°
73°
73.5°
73.5°
74.0°
Seat Angle
75.0°
74.0°
73.5°
73.3°
73.0°
72.5°
Wheel Base
971mm
975mm
978mm
986mm
1003mm
1018mm
Chain Stay Length
405mm
405mm
405mm
405mm
407mm
410mm
Front Center
577mm
580mm
583mm
591mm
605mm
617mm
Fork Offset
45mm
45mm
45mm
43mm
43mm
43mm
Stem Length
90mm
100mm
110mm
120mm
120mm
130mm
H/B Width
40 C-C
42 C-C
42 C-C
42 C-C
44 C-C
44 C-C
Crank Length
170mm
170mm
172.5mm
172.5mm
175mm
175mm
Seat Post Length
300mm
350mm
350mm
350mm
350mm
350mm
patmaessen
Topic gesloten, fiets gevonden, geen specialized maar scott........ Zal hem op het scott forum wel een keertje posten.
