Squadrats
Sulla
Sulla 16 aug 2026 16:32
Freek053 schreef: ↑16 aug 2026 11:20 Oops :shock:
Goed excuus om ook weer eens up te daten. Gisteren allerhande 'errants' gefietst door Zoetermeer. Vreselijk dorp voor squadrats. Alles lijkt op elkaar, er loopt geen weg recht en je houdt telkens de meest omnogelijke hoekjes en gaatjes over, en je gevoel van richting houdt daar gewoon op te bestaan.
Übersquadratinho:
Willem Altes.....................................33 x 33
Willem12..........................................30 x 30
TMK..................................................27 x 27
laurens87.........................................26 x 26
Polygoon...........................................18x 18
Rhino7/2...........................................18 x 18
Sulla................................................. 17 x 17
BertL.................................................16 x 16
Bakboord1........................................15 x 15
lnnrtlnnrt..........................................15 x 15
Anneroel...........................................13 x 13
ultra_ivo...........................................13 x 13
Globeskater......................................12 X 12
Raassie.............................................12 x 12
Freek053..........................................12 x 12
McMiGHtY.........................................11 x 11
DDX...................................................11x11
WDFL................................................. 9 x 9
Galileo………………………………………….9 X 9
Haka…………………………………………....7 X 7
Yardinho:
Willem Altes .................................62687
Willem12.......................................11993
laurens87........................................6125
TMK.................................................3835
Sulla.................................................3481
Rhino7/2..........................................3392
Anneroel..........................................3314
Bakboord1.......................................1396
BertL............................................... 1348
Freek053.........................................1124
ultra_ivo............................................ 829
lnnrtlnnrt...........................................817
Raassie..............................................813
Polygoon............................................784
WDFL ................................................560
DDX....................................................499
Globeskater.......................................494
Haka... …….’………………………………… 288
McMiGHtY..........................................276
Galileo …….’………………………………… 267
Squadratinhos:
ultra_ivo.........................................580656
DDX................................................290996
laurens87.......................................256734
Rhino7/2........................................240291
Willem12........................................223347
Willem Altes...................................186820
BertL...............................................183093
Anneroel.........................................164852
Globeskater....................................153878
lnnrtlnnrt.........................................104255
McMiGHtY.........................................95487
TMK..................................................78458
Galileo ……….’…………………………….. 76951
Haka.................................................60152
Freek053..........................................59704
WDFL................................................58326
Raassie..............................................56500
Sulla..................................................45443
Bakboord1........................................43012
Polygoon...........................................17987
[/quote]
Willem Altes
Willem Altes 30 aug 2026 13:20
Willem Altes schreef: ↑27 dec 2025 20:04 Voor volgend jaar wil ik het iets rustiger aan doen. In plaats van een groei van de Yardinho met 1500 minitegeltjes per maand lijkt mij 1250 tegeltjes mooi zat: doel dan 65.000.
Dat rustiger aandoen is mislukt. Het is nu eind augustus. Ik zit op 2/3 van het jaar en zit al op een yardinho van 65.000. Als ik de volgende maanden van 2026 in het voorgenomen "rustige": tempo doe, dan zit eind dit jaar op 70.000.
Übersquadratinho:
Yardinho:
Willem Altes .................................65268
Squadratinhos:
Willem Altes...................................190324
[/quote]
Sulla
Sulla 30 aug 2026 13:38
Mooi werk!
Trouwens bekend en vaker voorkomend iets dat bepaalde zaken juist harder gaan als je besloten hebt het rustiger aan te doen. Als een stukje 'druk er af is lijkt het soms ook soepeler te lopen.
Je bent trouwens naar de 2e plek opgeschoven :like:
Anneroel
Anneroel 23 okt 2026 18:18
Ubersquadrationho (+2) is nu verplaats van Annen naar Assen voor wat meer groeimogelijkheden.
Übersquadratinho:
Anneroel...........................................15 x 15
Yardinho:
Anneroel..........................................3813
Squadratinhos:
Anneroel.........................................174592
lnnrtlnnrt
lnnrtlnnrt 30 okt 2026 11:57
Mijn hardloopseizoen begint altijd met de wintertijd, dus ook weer tijd voor de 'kleine tegeltjes'. Ik moet nog één of twee keer de uiterwaarden van de IJssel in om m'n yardinho op Hattem aan te sluiten, dat geeft dan weer extra mogelijkheden. Zwolle begint langzaam vol te raken.
Übersquadratinho:
lnnrtlnnrt..........................................16 x 16
Yardinho:
lnnrtlnnrt...........................................849
Squadratinhos:
lnnrtlnnrt.........................................108666
raassie
raassie 30 okt 2026 12:43
Ook maar weer een kleine update, probeer zo af en toe nog wat te sprokkelen....
Übersquadratinho:
Yardinho:
Raassie..............................................921
Squadratinhos:
Raassie..............................................61482
Pijn is fijn, toch?
Mijn Strava: https://www.strava.com/athletes/10778731
Sulla
Sulla 05 nov 2026 12:24
Hoe update je squadrats als je veranderingen aan je activiteit hebt gedaan.
Was vergeten mijn wandeling in strava te beeindigen en heb nu een heel stuk met strava aan in de auto rondgereden.
DDX 05 nov 2026 14:23
Op edit icoontje klikken rechtsonderin en dan resync.
Sulla
Sulla 06 nov 2026 11:45
DDX schreef: ↑05 nov 2026 14:23 Op edit icoontje klikken rechtsonderin en dan resync.
Gevonden! dank je.
Echt 100x over dat icoontje heen gekeken :oops:
willem12
willem12 06 nov 2026 15:39
Telkens als ik ga stoppen breid ik cluster weer wat uit ;)
Übersquadratinho:
Yardinho:
Willem12.......................................23101
Squadratinhos:
Willem12........................................231442
raassie
raassie 13 nov 2026 13:02
Ondanks dat ik niet de meest fanatieke squadrater ben, toch voor een jaartje de Pro versie geprobeerd. Ik heb voor komend seizoen geen echt grote plannen staan, en op deze manier heb ik toch nog een klein zijdelings doel om eropuit te gaan. Vooral proberen om de woon-werk ritten dusdanig te plannen dat ik zonder overdreven ver om te rijden toch wat gaten dicht te rijden....ik vind het Garmin dataveld voor op de fiets erg handig (en misschien zelfs wel wat verslavend)
Pijn is fijn, toch?
