Squadrats
bakboord1
bakboord1 05 mar 2026 19:31
Yardinho weer verhoogd. Moet wel wat vaker de mountainbike pakken om kleine clusters te verbinden. Vaak ligt er geen verharde weg in de tegels.
Übersquadratinho:
Willem Altes.....................................33 x 33
Willem12..........................................30 x 30
TMK..................................................27 x 27
laurens87.........................................26 x 26
i-Mac ................................................20 x 20
Rhino7/2...........................................18 x 18
BertL.................................................16 x 16
Anneroel...........................................13 x 13
ultra_ivo...........................................13 x 13
Sulla................................................. 13 x 13
Globeskater......................................12 X 12
lnnrtlnnrt..........................................12 x 12
Raassie.............................................12 x 12
Bakboord…........................................12x12
Freek053..........................................12 x 12
McMiGHtY.........................................11 x 11
WDFL................................................. 9 x 9
Galileo………………………………………….9 X 9
Haka…………………………………………....7 X 7
Yardinho:
Willem Altes .................................50064
Willem12.........................................9166
laurens87.........................................6125
TMK.................................................3835
Rhino7/2..........................................3392
Sulla.................................................2659
Anneroel..........................................2405
i-Mac ............................................... 1412
BertL................................................ 1179
Bakboord…........................................757
Freek053......................................... 1083
ultra_ivo............................................ 829
lnnrtlnnrt...........................................766
WDFL ................................................560
Raassie..............................................537
Globeskater.......................................494
Haka... …….’………………………………… 288
Galileo …….’………………………………… 267
McMiGHtY..........................................263
Squadratinhos:
ultra_ivo.........................................580656
laurens87.......................................256734
Rhino7/2........................................240291
Willem12........................................216112
BertL...............................................173548
Willem Altes...................................169308
Anneroel.........................................160819
Globeskater....................................153878
lnnrtlnnrt.........................................103243
TMK..................................................78458
Galileo ……….’…………………………….. 76951
McMiGHtY.........................................75249
i-Mac ............................................... 64906
Haka.................................................60152
WDFL................................................58326
Freek053..........................................56197
Raassie..............................................52888
Sulla..................................................43031
Bakboord..........................................42579
Willem Altes
Willem Altes 08 mar 2026 00:03
Vandaag heb ik mijn Jan Klaassen afgemaakt. Dat is een Yardinho van Den Helder:
tot Den Briel:
Dat ging inderdaad niet allemaal op verharde wegen. Naar Den Helder heb ik bijvoorbeeld hele stukken over het strand geploeterd; die kleine tegeltjes liggen niet allemaal op plekken waar het zand lekker hard is.
Übersquadratinho:
Yardinho:
Willem Altes .................................52650
Squadratinhos:
Willem Altes...................................173467
Anneroel
Anneroel 09 mar 2026 13:31
Übersquadratinho:
Yardinho:
Anneroel..........................................3314
Squadratinhos:
Anneroel.........................................164852
Anneroel
Anneroel 09 mar 2026 13:38
Hierbij nog een plaatje. Deze winter met geploeter door natte weilanden van het Drentse gebied Aa eindelijk verbinding met Assen gemaakt. Kan daardoor komende tijd wat makkelijker scoren.
willem12
willem12 15 mar 2026 21:24
Door 10.000 heen met mijn cluster !! Merk dat ik het erg leuk vind om "onmogelijke" verbindingen toch werkend te krijgen. Kan nu bijvoorbeeld op 5 manieren naar Utrecht, terwijl er eerst maar één mogelijk leek. Wandelen en bushwacken is echt een wezenlijk onderdeel van Squadratinho's.
Mooi om te zien hoe iedereen het anders aanpakt.
Übersquadratinho:
Yardinho:
Willem12.......................................10012
laurens87........................................6125
BertL............................................... 1179
Squadratinhos:
Willem12........................................217915
DDX 16 mar 2026 15:55
Recent ook squadrats ook maar gaan gebruiken aangezien die wat klopperende info geeft of je een tegeltje wel of niet afgevinkt is.
Gisteren al een gekke, had nog een route gemaakt met veloviewer plugin en tegeltje afgevinkt maar schijnbaar had ik die op de een of andere manier al gehaald met squadrats.
Dus niet groen op squadrats.
Kan iemand deze verklaren ?
Volgens veloviewer gisteren dus pas behaald.
Tegel rechts er naast kwam ik na afloop pas achter dat ik die eigenlijk nog niet had, veloviewer loopt gps lijntje er net doorheen...
En ook even mijzelf in de lijst gezet, al zie je dat ik die squadratinho niet echt actief doe kwa cluster ;)
Übersquadratinho:
DDX...................................................11x11
Yardinho:
DDX....................................................499
Squadratinhos:
DDX................................................290996
DDX 16 mar 2026 16:04
En ben er zelf al achter, veloviewer zag hem niet door rechte lijn, terwijl die al over de weg liep die er doorheen loopt :
toch maar meer op squadrats gaan letten want op deze manier heb ik al aantal tegeltjes op veloviewer die ik eigenlijk niet heb gehaald
Laatst gewijzigd door DDX op 16 mar 2026 16:13, 3 keer totaal gewijzigd.
Sulla
Sulla 16 mar 2026 16:08
DDX schreef: ↑16 mar 2026 15:55
Je oude VV tegels beteken echt vrij weinig tot niets mbt squadratinho cluster. Goede kans dat je nog zat vakjes binnen 1 km van je huis hebt openstaan.
DDX 16 mar 2026 16:11
Sulla schreef: ↑16 mar 2026 16:08
Heel veel aangezien het veel polder/water is waar je niet legaal komt. (ja met bootje misschien)
Ga mij er dus zeker niet echt mee bezig houden :lol:
Übersquadratinho en Übersquadratinho ligt in Amsterdam Centrum en zou ik op die manier wel 'makkelijk' kunnen uitbreiden.
Al loop je daar ook snel tegen water aan. (wat ik soms wel afgevinkt heb met pontje zie ik en soms ook weer niet terwijl er lijntje doorheen loopt)
Dit idee :
Willem Altes
Willem Altes 17 mar 2026 20:24
Bij de westkant van het Java-eiland en het tegenover gekregen stukje Amsterdam-Noord, kan je zonder pont de verbinding naar Noord maken (en voor de verbinding Noord-Zaandam zijn er verschillende alternatieve oplossingen gevonden).
willem12
willem12 17 mar 2026 22:17
Maar ik ben gewoon heen en weer gelopen op de pont ván en náar de NDSM Werf. Dan is je cluster zo het IJ over.
Pontjes zijn eindeloos bediscusieerd op de verschillende fora en er is geen consensus. Ik zit in kamp meetellen.
Trein en zo niet natuurlijk.
DDX 17 mar 2026 22:32
Maar wanneer telt squadrats hem mee en wanneer niet, want van mijn screenshot zie je 1 tegeltje gevuld midden in het water en een andere weer niet.
En over meetellen, IJtunnel zou zeker moeten meetellen maarja gps trekt gewoon lijntjes van in en uitgang tunnel (rechts op mijn screenshot)
