Speling voorwiel
morel
morel 20 feb 2007 15:47
Zoals ik al zij en volgens het bovenvermelde artikel,
Although small, axle compression on QR hubs is large enough to alterbearing clearance and should be considered when adjusting bearings.Bearings should be adjusted just loose enough so that closing the QRleaves the bearing with a slight preload. Excessive preload from QRclosure is the cause of most wheel bearing failures not caused bywater intrusion. Clearance, in contrast can be felt as disconcertingrattle when encountering road roughness.
Ciao.
riherm1
riherm1 20 feb 2007 16:00
ok, thanks!
