campagnolo naaf radiaal spaken
colnagofreak
colnagofreak 22 feb 2008 21:34
Inmiddels antwoord gehad van Zoran, met de vraag of ik dit wilde delen op dit forum.
Zijn antwoord op de vraag dat Campa naven niet radiaal gespaakt mogen worden:
I know that.
And it concerns the front hub,more than the rear.
What the guys from fiets.forum. dont know is that the rear hub can be radially built,because the spoke tension ,on the non drive side of the rear hub, is below 80 kg.
The last 10 years, I have built all rear Campa hubs on the same way as I have built it for you .
Non of them cracked or whatsoever.
Of course you have my guaranty on the hub if anthing happens to the hub and it is caused by radially lacing the non drive side of the rear wheel.
Why radial spoking?
Radial spoke patterns produce a wheel that is both lighter and stronger! The direct load path is stiffer, allowing fewer or lighter spokes to be used so that the wheel does not ride harshly. Spokes lace into place without bending them around the hub or each other which reduces fatigue. All spokes radiate from the same side of the flange which equalizes tensions (unlike cross patterns which require a half centimeter disparity in center to flange dimension of inner versus outer spokes). On rear wheels spokes can be laced "heads out" on the non drive side and using special "race lace", "heads in" on the drive side. This reduces wheel dish significantly, again equalizing tensions. As long as a strong enough hub flange is used radial spoking is NOT more fragile and is actually more reliable than cross patterns. Radial spoking does require significant building skill to ensure the advantages previously stated, however once completed, the wheel can be trued easily. Radial spoking is not more popular because few wheels end up properly tensioned and cross patterns allow poorly built wheels to hold up reasonably well.
Rear Wheels
Heads-in" spoking on drive side vs "head-out" spoking on non drive to reduce dish (up to 50% reduction on ATB wheel dish, and up to 30% reduction on thr road wheel dhish) .Campagnolo hubs are with more dish offset than the other hubs.Laicing radialy rear wheels non drive side,I can build much stronger wheel.
These techniques can be applied to front disc brake wheels to increase strength and reliability as well. "
Maybe it's an idea you to share this info with the people on the forum?
Regards
Zoran.
sharkman113
sharkman113 22 feb 2008 22:42
Klopt wel wat hij zegt, alleen voordeel haal je er ook niet uit dus waarom dan radiaal spaken (afgezien van optisch mooi)
tiest
tiest 22 feb 2008 23:03
Sharkman 1 schreef:Klopt wel wat hij zegt, alleen voordeel haal je er ook niet uit dus waarom dan radiaal spaken (afgezien van optisch mooi)
Waarschijnlijk daarom dus. Geeft wel iets modern's hé.
ilko
ilko 22 feb 2008 23:19
Zoveel spakers zoveel meningen blijkbaar. Ernie Frieke heeft me ooit uitgelegd waarom het juist niet de voorkeur verdient. Hoe dan ook, als het weinig tot niets uitmaakt en de fabrikant het afkeurt, waarom zou je het dan toch doen?
de zwarten
Gebruikersavatar de zwarten 23 feb 2008 02:07
Allemaal goed en wel (ik heb hetzelfde antwoord gehad op mijn mail), maar ze zijn bij mij (en bij colnagofreak) wel 'heads in' radiaal gespaakt, in tegenstelling tot wat hierboven wordt aangeprezen...?
Afbeelding©®
colnagofreak
colnagofreak 23 feb 2008 08:06
Ik vind het allemaal nogal een storm in een glas water, Zoran staat bekend als een zeer ervaren en kundig wielbouwer, bovendien geeft hij de garantie als er iets mocht gebeuren door het half radial spaken van de naaf hij de verantwoordelijkheid/garantie op zich neemt.
Als hij al 10 jaar ervaring heeft met dit spaakpatroon, heb ik er wel vertrouwen in.
Eerst maar eens flink gaan rijden met de wieltjes dat lijkt mij de beste test.
de zwarten
Gebruikersavatar de zwarten 23 feb 2008 11:20
@ colnagofreak:
Daar gaat het niet om. Ik heb ook met blind vertrouwen mijn wielen besteld dankzij Zoran's reputatie. Maar dit is een legal issue, en die moet je niet oplossen via vertrouwen, maar via goede afspraken (maken goede vrienden). Ik ben blij dat Zoran achter zijn product staat. Maar als er iets gebeurt, wat dan? Dan zit je er wel mee. Je koopt ook geen huis met je vrienden of zelfs je broer/zus op basis van vertrouwen (bvb huis op jouw naam en ieder betaalt de helft). Je kan dan wel zeggen dat je elkaar vertrouwt, maar wat als er dan wat onvoorziens gebeurt...
indekken die handel dus!
Ik heb ondanks mijn openingspost steeds vertrouwen gehad in de wielen, maar een mens is dan wel verwonderd wanneer twee gereputeerde instanties (Zoran en Campagnolo) iets anders zeggen wat goed is.
antwoord van Zoran:
Hi
Just to clear up something regarding spoke lacing:
When the drive side is not race lace spoked
then the non drive side is with heads in.
If you pull a rope,with 100 kg of steel on the other side,
When are you stronger?
When you hold a rope over your shoulders,and walk forward,or when you hold the same rope
in front of you and walk backwards??
Imagine your body as a hub,spokes are the rope,and 100 kg of steel are the other spokes on the cassette side.
Zoran
Afbeelding©®
colnagofreak
colnagofreak 23 feb 2008 11:45
@ de zwarten
Zoran heeft toch op papier gezet dat hij de volle garantie geeft op het wiel en de naaf.
"Of course you have my guaranty on the hub if anthing happens to the hub and it is caused by radially lacing the non drive side of the rear wheel."
Dus ik bedoel hiermee te zeggen dat ik ook altijd wel vertrouwen gehad heb in de wielen, gezien de reputatie en kunde van Zoran als wielbouwer, en dat dit geen experiment van hem is zoals hier gesuggereerd werd.
Dat er op dit forum over wielen en de manier van bouwen verschillende meningen zijn is alleen maar goed en dat respecteer ook, maar wat is de waarheid?
Daarom laten we deze wieltjes eens flink aan de tand voelen, met de garantie van Zoran op zak! ;)
campasuper
campasuper 23 feb 2008 13:23
Is hij dan ook vreantwoordelijk voor de gevolgschade?
Stel je voor dat je je frame van 3.000,= Euro moet afschrijven.
Kleine lettertjes?
colnagofreak
colnagofreak 23 feb 2008 13:45
Kleine lettertjes?
Als ik ergens de pest aan heb is dat gezever over kleine lettertje e.d. amerikaanse toestanden over elkaar aansprakelijk stellen, overal stickers opplakken om onder de aansprakelijkheid uit te komen! Zoran lijkt mij niet de man die je op weg stuurt met een produkt waar hijzelf niet achter staat!
Met Mavic ES spaakbreuk, zo'n slag dat mijn achterwiel vastsloeg tegen de achterbrug, binnenkant van de achterbrug beschadigd en met moeite staande gebleven. Probeer dat maar eens te claimen bij Mavic! Dus gevolgschade??
Misschien dom, maar ik heb er gewoon vertrouwen in!
Zoals het er uitziet met een 32 gaats naaf, daar staat echt nog wel voldoende materiaal.
Ik ga hier echt geen voorschot op mijn verdriet nemen!
Hoop er dit jaar flink wat kilometers mee te maken, om hierna mijn bevindingen hier te delen.
de zwarten
Gebruikersavatar de zwarten 24 feb 2008 11:45
En na volgende mail ga ik helemaal met een gerust hart rijden:
Lieven
I forgot to tell you this;
I will give you guaranty of 3 years on the flansbreuk,I dont have any problem with that.
I have built the wheels for the Skil Moser team the same way.There was no problem with the wheels.
I have build you an exellent wheel set,and I know that.
I used the best possible option for Campagnolo hubs,which you can not compare with Ultegra hubs,used by the Krolston team.
I have mixed the spokes the same way I mixed the spokes for Kroloston team,the only difference is in the non cassette side.
I had to change it because of the different hub.
REgards
Zoran
Afbeelding©®
