ericpeters heeft gelijk. Carbonfibers worden geproduceerd door polyacrilonitrile (PAN) uit te harden onder hoge temperaturen (waarbij oxidatie en pyrolyse plaats vindt).
Aangezien acrylonitrile uit propeen (direkt afkomstig uit de olie-industrie) en ammoniak wordt gemaakt kan je dus inderdaad stellen dat carbon geen duurzaam product is.
Maar afgezien van het feit dat er dus fossiele brandstoffen bij zijn betrokken is het productieproces van PAN niet erg milieuvriendelijk. Zo is er een aanzienlijke productie van het zeer giftige HCN (HCN:AN = 1:9).
Het volgende staat erover geschreven in wikipedia:
Each carbon filament is made out of long, thin filaments of carbon sometimes transformed to graphite. A common method of making carbon filaments is the oxidation and thermal pyrolysis of polyacrylonitrile (PAN), a polymer based on acrylonitrile used in the creation of synthetic materials. Like all polymers, polyacrylonitrile molecules are long chains, which are aligned in the process of drawing continuous filaments. A common method of manufacture involves heating the PAN to approximately 300 °C in air, which breaks many of the hydrogen bonds and oxidizes the material. The oxidized PAN is then placed into a furnace having an inert atmosphere of a gas such as argon, and heated to approximately 2000 °C, which induces graphitization of the material, changing the molecular bond structure. When heated in the correct conditions, these chains bond side-to-side (ladder polymers), forming narrow graphene sheets which eventually merge to form a single, jelly roll-shaped or round filament. The result is usually 93-95% carbon. Lower-quality fiber can be manufactured using pitch or rayon as the precursor instead of PAN. The carbon can become further enhanced, as high modulus, or high strength carbon, by heat treatment processes. Carbon heated in the range of 1500-2000 °C (carbonization) exhibits the highest tensile strength (820,000 psi or 5,650 MPa or 5,650 N/mm²), while carbon fiber heated from 2500 to 3000 °C (graphitizing) exhibits a higher modulus of elasticity (77,000,000 psi or 531 GPa or 531 kN/mm²).
